Synthesizing design for PAC with Arria 10 GX fails
- 6 years ago
Thanks for the report file. It looks like there is a conflict on the your Quartus design where the IP name use is the same.
Below is the error message when Quartus Synthesis is performed. You will need to make some changes on your design so that it is not using the same file name.
Error (19021): The same file name "mm_bridge_0" is used for different IP files. The same name cannot be used for more than one IP file.
Yes, may I know why you performed the update? Could you check how many Quartus is installed on your system?
- RBash6 years ago
Honestly, I don't remember why but yesterday I downloaded the update and wanted to install it, and encountered a message that said I have already installed the update and the patch. I have two Quartus installations, 18.0 for running HLS and 17.1.1 for synthesis, but before running synthesis I source the init_env.sh script in the Quartus 17.1.1 path which sets the QUARTUS_HOME environment variable to point to Quartus 17.1.1.
