Synthesizing design for PAC with Arria 10 GX fails
- 6 years ago
Thanks for the report file. It looks like there is a conflict on the your Quartus design where the IP name use is the same.
Below is the error message when Quartus Synthesis is performed. You will need to make some changes on your design so that it is not using the same file name.
Error (19021): The same file name "mm_bridge_0" is used for different IP files. The same name cannot be used for more than one IP file.
May I know if you are using Quartus that is part of the Intel Acceleration Stack? The reason is that you should be using Quartus 17.1.1 with Patch 136_138.
I am using the Quartus version that's part of the Intel Acceleration Stack, but I attempted installing the 17.1.1.273 update and it turned out I had already done that, also with patch 1.01dcp;1.02dcp;1.36;1.38;1.03dcp. Is this what you're referring to?
