Synthesizing design for PAC with Arria 10 GX fails
- 6 years ago
Thanks for the report file. It looks like there is a conflict on the your Quartus design where the IP name use is the same.
Below is the error message when Quartus Synthesis is performed. You will need to make some changes on your design so that it is not using the same file name.
Error (19021): The same file name "mm_bridge_0" is used for different IP files. The same name cannot be used for more than one IP file.
Let me try to re-run everything from HLS to Quartus compilation from my side again.
May I know which Quartus version are you using? Many system have you tested?
- RBash6 years ago
Thank you. I use Quartus 18.0 for HLS compilation, and 17.1 for synthesis.
I just tested on one machine, as I don't have access to other machines with Arria 10 cards. Or do you mean how many systems I tried to synthesize? If that's the case, I tried one other system that also failed.
