Synthesizing design for PAC with Arria 10 GX fails
- 6 years ago
Thanks for the report file. It looks like there is a conflict on the your Quartus design where the IP name use is the same.
Below is the error message when Quartus Synthesis is performed. You will need to make some changes on your design so that it is not using the same file name.
Error (19021): The same file name "mm_bridge_0" is used for different IP files. The same name cannot be used for more than one IP file.
Hmm, just to confirm the project that you provided is with the latest design right? Not sure if you are able to compile the design that you provided to me?
- RBash6 years ago
Yes, it is the latest design. I tried compiling that same project that I sent you and I face the above error. But the error isn't specific to this project, when I try other relatively big designs I get this error too, whereas smaller designs just compile fine in a matter of several hours.
