RBash
6 years agoSynthesizing design for PAC with Arria 10 GX fails
I'm trying to synthesize a design for a PAC with Arria 10 GX, but get the following messages when the synthesis script finishes. Since the error message doesn't give any particular information, I don...
- 6 years ago
Thanks for the report file. It looks like there is a conflict on the your Quartus design where the IP name use is the same.
Below is the error message when Quartus Synthesis is performed. You will need to make some changes on your design so that it is not using the same file name.
Error (19021): The same file name "mm_bridge_0" is used for different IP files. The same name cannot be used for more than one IP file.
JohnT_Altera
6 years agoNo, do you try to recompile your design again? I am able to fully compile the design.
RBash
6 years agoYes, I have tried multiple times but the same error appears. In case this information helps, I have a Xeon Skylake Gold 6140M CPU, an Intel S2600WF server, and the OS is CentOS 7.6.
