Synthesizing design for PAC with Arria 10 GX fails
- 6 years ago
Thanks for the report file. It looks like there is a conflict on the your Quartus design where the IP name use is the same.
Below is the error message when Quartus Synthesis is performed. You will need to make some changes on your design so that it is not using the same file name.
Error (19021): The same file name "mm_bridge_0" is used for different IP files. The same name cannot be used for more than one IP file.
I have no detail of the failure as the rpt file you provided only shows synthesis failure without any detail information. Not sure if you have synthesis each of the design previously?
No I didn't synthesize each module previously. The only thing I do before the three commands I mentioned is to generate HDL for the .qsys systems I have. If any particular file in the build directory would be helpful, I can upload that as well.
