Synthesizing design for PAC with Arria 10 GX fails
- 6 years ago
Thanks for the report file. It looks like there is a conflict on the your Quartus design where the IP name use is the same.
Below is the error message when Quartus Synthesis is performed. You will need to make some changes on your design so that it is not using the same file name.
Error (19021): The same file name "mm_bridge_0" is used for different IP files. The same name cannot be used for more than one IP file.
From the error message, it failed to synthesis the partition. You might need to try out each to compile each of your partition or module.
- RBash6 years ago
Thank you for your response. The steps I take now are the following:
$ afu_synth_setup --source=rtl/filelist.txt build_fpga $ cd build_fpga/ $ $OPAE_PLATFORM_ROOT/bin/run.shSo what you suggest is I compile each of my .qsys files manually using Quartus instead? And then how do I combine them all to generate a programming bitstream? Can you please point me to a document on how to do that if there exists one?
