RBash
6 years agoSynthesizing design for PAC with Arria 10 GX fails
I'm trying to synthesize a design for a PAC with Arria 10 GX, but get the following messages when the synthesis script finishes. Since the error message doesn't give any particular information, I don...
- 6 years ago
Thanks for the report file. It looks like there is a conflict on the your Quartus design where the IP name use is the same.
Below is the error message when Quartus Synthesis is performed. You will need to make some changes on your design so that it is not using the same file name.
Error (19021): The same file name "mm_bridge_0" is used for different IP files. The same name cannot be used for more than one IP file.
RBash
6 years agoHi John,
I was wondering if you could help me with another similar synthesis failure. This one is in a bigger design (although I still expect it to use ~60% of ALMs), and I don't have any IP files with the same name. I looked for the error you had found in the previous log, and it wasn't present in the log.
Thanks in advance.
