Synthesis - Incorrect SystemVerilog interface parameter override
- 3 years ago
Hi @fxmelvin ,
FYI. The bug had been fixed and implemented in Quartus Pro Edition version 22.4 internal build. Tested and worked fine check the image below:
Kindly wait for the version release. Thank you for your patience.
Sheng
I notice you use localparam for logic INIT_V in mem_if. Try don't to use that else DATA_W and ADDR_W will be assigned with local parameter. Delete the localparam and add INIT_V to modport mem will do.
Sheng
The original code is correct SystemVerilog usage and does not have to be changed; parameter dependence is a well understood aspect of SystemVerilog, having even a dedicated section in the standard explaining how overriding the relevant parameters during instantiation implies that the final parameter value must refer to that instead of any defaults.
Furthermore, if I understand what you're suggesting, i.e. have INIT_V as part of the mem.sv, that's not good enough for my use case; the example shared in this post is just a minimal, reproducible example of the original problem.
Lastly, note that the same code is synthesized correctly by other FPGA tools like Vivado.
- ShengN_altera4 years ago
Hi @fxmelvin ,
I have read through your post and understand what you are asking for now. Anywhere, I'll reflect this particular problem to internal engineering for further ado. Thanks for your sharing.
Sheng
