Armando1989's avatar
Armando1989
2 years ago
SYNCHRONIZED RS232 DATA CORRUPTED
Hi there!!.
Set up attached project, capturing rs232 1200baud data and latch each byte to leds.
Project compiles and pass timing constraints wo issue. Simulation testbench also gives correct result. However when connected to max3232 board and send characters by teraterm, specially close followed... data seems corrupted. I use to send a line of 000000 on a file or several 0 by pressing rapidly, that reproduces iisue easier.
Whole design is using 50MHz clock and a clock enable signal which triggers each 1200Hz hz and drives the FSM, the capturer and the synchronizer. (Clock enable usage is suggested to use just one clock domain). system.v connects all submodules.
In design ive routed rx_in_sync output to external pin to check the rs232 data being pass to 2 flops synchronizers synced with clock enable signal.
Ive check that from time to time rx_in_sync edges are missalingned with the rs232 data from max3232 board. If that output is bad, then FSM and counter will get also corrupted data and of course leds sometime will show wrong characters... So issue is already present between clock enable generator and the actual synchronizer as below:
Clock enable signal is sent to 2 flop synchronizer-->clock enable_sync
clock enable_sync is sent to 2 flop synchronizers with clock enable input, this 2 flop sync receives the rs232 RX_IN from outside to give-->rx_in_sync as output.
In yellow is the original 1200baud rs232 byte "30" thats ascii "0".
In blue is the "rx_in_sync output" which sometimes has edges missaligned as u can see below. My scope clearly cannot decode when issue happens:
ok case
bad case, wrong edges
Anyone has come across this situation when synchronize async input data?
Thanks in advance!
BR
  • I read the code so that you are sampling 1200 Baud UART input at 1200 Hz only. I'd expect oversampling with e.g. factor 8 as any usual UART does. Or did I miss code details?
    There's no use of synchronizing Rx at a reduced rate, this can be done with full clock rate, e.g. 50 MHz.
    Decoding of UART data at suitable oversampling rate allows to detect start bit falling edge with necessary accuracy and start to sample data bits after 1/2 bit duration.
  • FvM's avatar
    FvM
    • Armando1989's avatar
      Armando1989
      Hi FvM
      Thanks for your reply.
      Yes. At first i just synced rx data with 50MHz clock itself but found out also sometimes bytes are corrupted.
      FSM and Counter works on 1200Hz, otherwise would need to add some counter ie if i use clock enable at 3600 to sample in the middle only for the counter but fsm must work on high frec if i want to capture start bit accurately i guesss..
      Weird thing is simulation works fine jejej
      • FvM's avatar
        FvM
        working simulation doesn't mean much if you don't test different timing relations between clock and data.
        Although it can be instructive to design UART from the scratch, it's also a good idea to take a look at one of many existing designs.
