jjxichn's avatar
jjxichn
2 years ago
subtractor in quartus
Hello All, I am new to Altera and I am using Agilex to do some interesting stuff. Does any one know whether Quartus Prime 20.4 have ip core to do subtraction with embedded pipelines? I only see Multiply Adder Intel FPGA IP core inside it. What is the best way to do subtraction? Shall I write it in verilog explictly?
  • Hi,
    you can use Fixed Point Functions IP, Parrallel Add. Substraction is generated by giving a minus sign to one input parameter.
    It has all options to set different pipeline levels and estimates speed.
  • FvM's avatar
    FvM
    did you notice the "+/-" symbol in DSP block schematic? Fixed and float IP perform both add and substract.
    • jjxichn's avatar
      jjxichn
      That +/- is only for DSP. But I prefer to use ALMs. So I am curious if we can use any IPs to do substraction using ALMs as a pipelined fashion?
  • FvM's avatar
    FvM
  • ShengN_altera's avatar
    ShengN_altera
    Do you have any further update or concern?
    Sheng
