15 years agoStruggling with Quartus II
Hi All,
I am a new user to Altera's Quartus II and to FPGA's in general. I have posted already on a similar matter, but had no replies so thought I'd try again. I am using the FTDI Morph-IC-II board, and am struggling to get the communications between the Altera Cyclone-II FPGA and the FTDI FT2232 chip to work properly. I configured the FTDI chip for communication using the synchronous 245 FIFO mode to interface with the FPGA. I also have made a simple quartus II design which only has one Warning and as that is "warning: feature logiclock is only available with a valid subscription license. you can purchase a software subscription to gain full access to this feature." I should be fine to ignore it. The thing that is confusing me most, is that when I do not have anything on the FPGA, the RXF# and TXE# signals which go between the FTDI chip and the FPGA work correctly. However when I try to impliment my design onto the FPGA these signals are held high. I think I must have a problem with how I have set up the pins in my quartus II design, but I have been through many of the tutorials and web/e seminars and feel I am doing as I have been shown in the examples. However I am thoroughly stuck and slowly getting annoyed at the Altera software, as no matter what I do, even with no errors, nothing seems to be workin. Any help, advice or guidance is very welcome and extremely appreciated!
