Stratix 10 Transceiver toolkit
- 2 years ago
I have a look into your IP design. I found that your IP design not meet below requirement. In the user guide, it has mentioned about that to enable Intel® Stratix® 10 transceiver toolkit capability in the Native PHY IP core, you must enable the following options:
- Enable dynamic reconfiguration
- Enable Native PHY Debug Master Endpoint
- Enable capability registers
- Enable control and status registers
- Enable PRBS (Pseudo Random Binary Sequence) soft accumulators
For further information, you may refer to link below, Section 2.3.10, https://www.intel.com/content/www/us/en/docs/programmable/683621/current/dynamic-reconfiguration-parameters.html
Please do try enable the above options and compile the design again. Please do try run the system console again to see the error still exist anot.
zying
I found that your design compilation was fail. Please make sure your design was compiled successfully, then can proceed to the programmer and system console.
zying
Hello Zying,
Have you had a chance to look at this design?
