Stratix 10 Transceiver toolkit
- 2 years ago
I have a look into your IP design. I found that your IP design not meet below requirement. In the user guide, it has mentioned about that to enable Intel® Stratix® 10 transceiver toolkit capability in the Native PHY IP core, you must enable the following options:
- Enable dynamic reconfiguration
- Enable Native PHY Debug Master Endpoint
- Enable capability registers
- Enable control and status registers
- Enable PRBS (Pseudo Random Binary Sequence) soft accumulators
For further information, you may refer to link below, Section 2.3.10, https://www.intel.com/content/www/us/en/docs/programmable/683621/current/dynamic-reconfiguration-parameters.html
Please do try enable the above options and compile the design again. Please do try run the system console again to see the error still exist anot.
zying
I found that your design compilation was fail. Please make sure your design was compiled successfully, then can proceed to the programmer and system console.
zying
Ah, my mistake. Attached to this message is a new qar archive that I confirmed works.
The transceiver IPs are instantiated in "interlaken_MGT.vhd".
The top level entity is in "4.._fpga_target_hw_devkit_s10_devkit_top_ent.vhd", but the architecture is in a separate file: "interlaken_MGT_arch.vhd"
Thank you again for helping me!
