18 years agoHello Axel,
I can contribute another interesting observation regrading your code example. In the detail below, you see that the if trafficlight_ena = '1' then condition is always true cause it is evaluated after the preceeding if trafficlight_ena = '0' then.if trafficLight_ena = '0' then
reset_timer_var := '1';
state <= init;
else
case state is
when init =>
output <= "00";
if trafficLight_ena = '1' then -- always true, but...
state <= red;
end if; Whatever the compiler may synthezise from the redundant IF statement, it produces a third netlist variant if you omit it and a possible else state <= init statement. Try yourself. Furthermore, the coding differences from additional else in green and red state are vanishing. Somewhat surprizing. I stumbled on the "dead code", when I tryed to understand, if the different netlists would cause identical behaviour. Regards, Frank
