State Machine Bus Name Format
I'm using Quartus v 13.1 for Cyclone III. The State Machine Wizard only seems to allow input/output bus names with a name[N:0] format but the compiler flags a 275021 error if bus names aren't in a name[N..0] format. Which is correct? How does this conflict get resolved? Thanks.
- sstrell
Can you show the exact error message and the HDL code generated by the State Machine Editor?
- BigSid
Here's the error message:
Error (275021): Illegal wire or bus name "mif_select[7:0]" of type port
Error (275021): Illegal wire or bus name "counter[2:0]" of type port
Error (12152): Can't elaborate user hierarchy "Down_Counter_Clock_Select:inst100"
Error: Quartus II 64-Bit Analysis & Elaboration was unsuccessful. 3 errors, 3 warnings
Error: Peak virtual memory: 4672 megabytes
Error: Processing ended: Thu Sep 02 14:51:28 2021
Error: Elapsed time: 00:00:03
Error: Total CPU time (on all processors): 00:00:03And here's the HDL code generated by the State Machine Wizard:
-- Copyright (C) 1991-2014 Altera Corporation
-- Your use of Altera Corporation's design tools, logic functions
-- and other software and tools, and its AMPP partner logic
-- functions, and any output files from any of the foregoing
-- (including device programming or simulation files), and any
-- associated documentation or information are expressly subject
-- to the terms and conditions of the Altera Program License
-- Subscription Agreement, Altera MegaCore Function License
-- Agreement, or other applicable license agreement, including,
-- without limitation, that your use is for the sole purpose of
-- programming logic devices manufactured by Altera and sold by
-- Altera or its authorized distributors. Please refer to the
-- applicable agreement for further details.-- Generated by Quartus II Version 13.1.4 Build 182 03/12/2014 SJ Web Edition
-- Created on Wed Sep 01 14:28:57 2021LIBRARY ieee;
USE ieee.std_logic_1164.all;ENTITY ROM_Select_State_Machine IS
PORT (
reset : IN STD_LOGIC := '0';
clock : IN STD_LOGIC;
mif_select : IN STD_LOGIC_VECTOR(7 DOWNTO 0) := "00000000";
busy : IN STD_LOGIC := '0';
counter : IN STD_LOGIC_VECTOR(2 DOWNTO 0) := "000";
mif_select_changed : IN STD_LOGIC := '0';
write_from_rom : OUT STD_LOGIC;
reconfig : OUT STD_LOGIC;
enable_counter : OUT STD_LOGIC;
clear_counter : OUT STD_LOGIC
END ROM_Select_State_Machine;ARCHITECTURE BEHAVIOR OF ROM_Select_State_Machine IS
TYPE type_fstate IS (state1,state2,state3,state4,state5,state6,state7,state8,state9);
SIGNAL fstate : type_fstate;
SIGNAL reg_fstate : type_fstate;
BEGIN
PROCESS (clock,reg_fstate)
BEGIN
IF (clock='1' AND clock'event) THEN
fstate <= reg_fstate;
END IF;
END PROCESS;PROCESS (fstate,reset,mif_select,busy,counter,mif_select_changed)
BEGIN
IF (reset='1') THEN
reg_fstate <= state1;
write_from_rom <= '0';
reconfig <= '0';
enable_counter <= '0';
clear_counter <= '0';
ELSE
reconfig <= '0';
CASE fstate IS
WHEN state1 =>
IF ((mif_select(7 DOWNTO 0) /= "00000000")) THEN
reg_fstate <= state2;
-- Inserting 'else' block to prevent latch inference
ELSE
END IF;enable_counter <= '0';
reconfig <= '0';
WHEN state2 =>
IF (NOT((busy = '1'))) THEN
reg_fstate <= state3;
ELSE
reconfig <= '0';
WHEN state3 =>
IF ((counter(2 DOWNTO 0) = "001")) THEN
reg_fstate <= state4;
ELSE
END IF;enable_counter <= '1';
reconfig <= '0';
WHEN state4 =>
IF ((counter(2 DOWNTO 0) = "010")) THEN
reg_fstate <= state5;
ELSE
reconfig <= '0';
write_from_rom <= '1';
WHEN state5 =>
IF ((busy = '1')) THEN
reg_fstate <= state6;
ELSE
reconfig <= '0';
WHEN state6 =>
reg_fstate <= state7;
ELSE
reconfig <= '0';
WHEN state7 =>
IF ((counter(2 DOWNTO 0) = "011")) THEN
reg_fstate <= state8;
ELSE
reconfig <= '0';
WHEN state8 =>
IF ((counter(2 DOWNTO 0) = "100")) THEN
reg_fstate <= state9;
ELSE
reconfig <= '1';
WHEN state9 =>
IF ((mif_select_changed = '1')) THEN
ELSE
clear_counter <= '1';
reconfig <= '0';
WHEN OTHERS =>
write_from_rom <= 'X';
reconfig <= 'X';
enable_counter <= 'X';
clear_counter <= 'X';
report "Reach undefined state";
END CASE;
END IF;
END PROCESS;
END BEHAVIOR;Thanks for any help you could provide.
- sstrell
The state machine code you generated from the State Machine Editor is VHDL. Is your overall design Verilog or VHDL?
- BigSid
I'm doing the design via schematic entry and have selected VHDL file generation at every step when prompted. However, one of the state machine files that was generated (ROM_Select_State_Machine_inst) is listed in my file folder as a "Verilog File Type" even though I was never asked to select the type. Could this be causing an issue? If so, how can this be corrected?
- Nurina
Did above comment help?
