State Machine Bus Name Format
Here's the error message:
Error (275021): Illegal wire or bus name "mif_select[7:0]" of type port
Error (275021): Illegal wire or bus name "counter[2:0]" of type port
Error (12152): Can't elaborate user hierarchy "Down_Counter_Clock_Select:inst100"
Error: Quartus II 64-Bit Analysis & Elaboration was unsuccessful. 3 errors, 3 warnings
Error: Peak virtual memory: 4672 megabytes
Error: Processing ended: Thu Sep 02 14:51:28 2021
Error: Elapsed time: 00:00:03
Error: Total CPU time (on all processors): 00:00:03
And here's the HDL code generated by the State Machine Wizard:
-- Copyright (C) 1991-2014 Altera Corporation
-- Your use of Altera Corporation's design tools, logic functions
-- and other software and tools, and its AMPP partner logic
-- functions, and any output files from any of the foregoing
-- (including device programming or simulation files), and any
-- associated documentation or information are expressly subject
-- to the terms and conditions of the Altera Program License
-- Subscription Agreement, Altera MegaCore Function License
-- Agreement, or other applicable license agreement, including,
-- without limitation, that your use is for the sole purpose of
-- programming logic devices manufactured by Altera and sold by
-- Altera or its authorized distributors. Please refer to the
-- applicable agreement for further details.
-- Generated by Quartus II Version 13.1.4 Build 182 03/12/2014 SJ Web Edition
-- Created on Wed Sep 01 14:28:57 2021
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY ROM_Select_State_Machine IS
PORT (
reset : IN STD_LOGIC := '0';
clock : IN STD_LOGIC;
mif_select : IN STD_LOGIC_VECTOR(7 DOWNTO 0) := "00000000";
busy : IN STD_LOGIC := '0';
counter : IN STD_LOGIC_VECTOR(2 DOWNTO 0) := "000";
mif_select_changed : IN STD_LOGIC := '0';
write_from_rom : OUT STD_LOGIC;
reconfig : OUT STD_LOGIC;
enable_counter : OUT STD_LOGIC;
clear_counter : OUT STD_LOGIC
END ROM_Select_State_Machine;
ARCHITECTURE BEHAVIOR OF ROM_Select_State_Machine IS
TYPE type_fstate IS (state1,state2,state3,state4,state5,state6,state7,state8,state9);
SIGNAL fstate : type_fstate;
SIGNAL reg_fstate : type_fstate;
BEGIN
PROCESS (clock,reg_fstate)
BEGIN
IF (clock='1' AND clock'event) THEN
fstate <= reg_fstate;
END IF;
END PROCESS;
PROCESS (fstate,reset,mif_select,busy,counter,mif_select_changed)
BEGIN
IF (reset='1') THEN
reg_fstate <= state1;
write_from_rom <= '0';
reconfig <= '0';
enable_counter <= '0';
clear_counter <= '0';
ELSE
reconfig <= '0';
CASE fstate IS
WHEN state1 =>
IF ((mif_select(7 DOWNTO 0) /= "00000000")) THEN
reg_fstate <= state2;
-- Inserting 'else' block to prevent latch inference
ELSE
END IF;
reconfig <= '0';
WHEN state2 =>
IF (NOT((busy = '1'))) THEN
reg_fstate <= state3;
ELSE
END IF;
reconfig <= '0';
WHEN state3 =>
IF ((counter(2 DOWNTO 0) = "001")) THEN
reg_fstate <= state4;
ELSE
END IF;
enable_counter <= '1';
reconfig <= '0';
WHEN state4 =>
IF ((counter(2 DOWNTO 0) = "010")) THEN
reg_fstate <= state5;
ELSE
END IF;
reconfig <= '0';
write_from_rom <= '1';
WHEN state5 =>
IF ((busy = '1')) THEN
reg_fstate <= state6;
ELSE
END IF;
reconfig <= '0';
WHEN state6 =>
reg_fstate <= state7;
ELSE
END IF;
reconfig <= '0';
WHEN state7 =>
IF ((counter(2 DOWNTO 0) = "011")) THEN
reg_fstate <= state8;
ELSE
END IF;
reconfig <= '0';
WHEN state8 =>
IF ((counter(2 DOWNTO 0) = "100")) THEN
reg_fstate <= state9;
ELSE
END IF;
reconfig <= '1';
WHEN state9 =>
IF ((mif_select_changed = '1')) THEN
ELSE
END IF;
clear_counter <= '1';
reconfig <= '0';
WHEN OTHERS =>
write_from_rom <= 'X';
reconfig <= 'X';
enable_counter <= 'X';
clear_counter <= 'X';
report "Reach undefined state";
END CASE;
END IF;
END PROCESS;
END BEHAVIOR;
Thanks for any help you could provide.
The state machine code you generated from the State Machine Editor is VHDL. Is your overall design Verilog or VHDL?
- BigSid5 years ago
I'm doing the design via schematic entry and have selected VHDL file generation at every step when prompted. However, one of the state machine files that was generated (ROM_Select_State_Machine_inst) is listed in my file folder as a "Verilog File Type" even though I was never asked to select the type. Could this be causing an issue? If so, how can this be corrected?
- sstrell5 years ago
No, that's the instantiation template for Verilog.
So you're creating a schematic design? Can you share that? This may be in your schematic design, not the state machine code.
