BigSid
5 years agoState Machine Bus Name Format
I'm using Quartus v 13.1 for Cyclone III. The State Machine Wizard only seems to allow input/output bus names with a name[N:0] format but the compiler flags a 275021 error if bus names aren't in a na...
sstrell
5 years agoThe state machine code you generated from the State Machine Editor is VHDL. Is your overall design Verilog or VHDL?
BigSid
5 years agoI'm doing the design via schematic entry and have selected VHDL file generation at every step when prompted. However, one of the state machine files that was generated (ROM_Select_State_Machine_inst) is listed in my file folder as a "Verilog File Type" even though I was never asked to select the type. Could this be causing an issue? If so, how can this be corrected?
- sstrell5 years ago
No, that's the instantiation template for Verilog.
So you're creating a schematic design? Can you share that? This may be in your schematic design, not the state machine code.
