CHatz
2 years agoStartup problem with Questa Simulator.
When I invoke Questa, it displays the following message: I downloaded the latest version from the Quartus Lite package, and I still get the same message. Any ideas or suggestions?
ShengN_altera
2 years agoHi,
Are you using window version? Does the supported OS environment being used? Are you invoking questa straight away from vsim.exe? I had tested without problem check attached. May be try to re-install.
Sheng
