14 years ago
ST Avalon Source/Sink Template or component example
I need to interface my custom module with SGDMA component in SOPC system...so I need to implement a ST Avalon interface to do that....
Do you know any Template to use??? or how create a custom block with an ST Avalon interface???
1 Reply
    I don't know of any template since it's a trivial interface (if valid and ready are high, data moves from the source to the sink). I would generate a streaming FIFO in Qsys and take a look at the logic implementing it. You'll find the output data of the FIFO wires up the ST valid signal to "not empty" and the input side will use "not full".
