8 years agoSR latch test bench help
Hey im not sure how to make a testbench for an sr latch, the code ive made is shown below for the latch and the testbench. for the latch library ieee; use ieee.std_logic_1164.all; ...
8 years agoIm having problems getting an output in the simulator in modelsim for rl sl qa and qb, i changed the code a bit so it shows r s and q on the simulator.
library ieee; use ieee.std_logic_1164.all; entity Testbench6a is end Testbench6a; architecture struct of Testbench6a is component tut6a port ( clk , r , s : in std_logic; q : out std_logic); end component; signal s , r , q : std_logic := '0'; signal rl , sl , qa , qb : std_logic := '0'; signal clk : std_logic := '1'; begin inst1 : tut6a port map( clk , r , s , q ); process begin s <= '0'; r <= '0'; wait for 10 ns; s <= '1'; r <= '0'; wait for 10 ns; s <= '0'; r <= '1'; wait for 10 ns; s <= '1'; r <= '1'; wait; end process; end architecture;
