8 years agoSR latch test bench help
Hey im not sure how to make a testbench for an sr latch, the code ive made is shown below for the latch and the testbench.
for the latch library ieee; use ieee.std_logic_1164.all; entity tut6a is port ( end tut6a; architecture struct of tut6a is signal r1 , s1, qa , qb : std_logic; attribute keep : boolean; attribute keep of r1 , s1 , qa , qb : signal is true; begin r1 <= r and clk; s1 <= s and clk; qb <= not (r1 and qa); qa <= (s1 and qb); q <= qa; end struct; for the testbench library ieee; use ieee.std_logic_1164.all; entity Testbench6a is end Testbench6a; architecture struct of Testbench6a is component tut6a port ( clk , r , s : in std_logic; qa , qb , rl , sl : out std_logic); end component; signal s , r , q : std_logic := '0'; signal rl , sl , qa , qb : std_logic := '0'; signal clk : std_logic := '1'; begin inst1 : tut6a port map( clk , r , s , qa, qb, rl, sl ); process begin s <= '1'; r <= '0'; wait for 10 ns; s <= '0'; r <= '1'; wait for 10 ns; s <= '1'; r <= '1'; wait for 10 ns; end process; end architecture;3 Replies
What exactly do you need help with? It looks like you are following a tutorial (given an entity name name tut6a). If so, did you read something in this tutorial, or the ones before, regarding port mapping and such things?
Im having problems getting an output in the simulator in modelsim for rl sl qa and qb, i changed the code a bit so it shows r s and q on the simulator.
library ieee; use ieee.std_logic_1164.all; entity Testbench6a is end Testbench6a; architecture struct of Testbench6a is component tut6a port ( clk , r , s : in std_logic; q : out std_logic); end component; signal s , r , q : std_logic := '0'; signal rl , sl , qa , qb : std_logic := '0'; signal clk : std_logic := '1'; begin inst1 : tut6a port map( clk , r , s , q ); process begin s <= '0'; r <= '0'; wait for 10 ns; s <= '1'; r <= '0'; wait for 10 ns; s <= '0'; r <= '1'; wait for 10 ns; s <= '1'; r <= '1'; wait; end process; end architecture; - Altera_Forum
--- Quote Start --- Im having problems getting an output in the simulator in modelsim for rl sl qa and qb, i changed the code a bit so it shows r s and q on the simulator. --- Quote End --- Do you see rl sl and both q's in the simulator but do they have the value 'U' or do you not see them at all?
