15 years agoSource synchronous constraints for both edges in TimeQuest
I've been working my way through the tutorials and Rysc's document. Unfortunately, the waveforms don't match what I'd expect. I thought I'd see the min-rise output delays from the rising edge of the launch clock to the rising edge of the latch clock, and from the falling edge of the launch clock to the falling edge of the latch clock. The rising edge is always the launch, which seems wrong.
Here's what I do:# derive_clocks + correct periods.# for each link, there is an external clock shifted -90 degrees
create_clock -name {clock_source} -period 10.000 -waveform { 0.000 5.000 }
create_clock -name {l1_clk_in} -period 5.000 -waveform { 0.000 2.500 } }]
create_clock -name l1_tx_clk_0 -period 5.000 -waveform { 3.75 6.25 }
derive_pll_clocks
# HT output clock
create_generated_clock -source U_HT_CORE|U_HT_EC|htxtop_inst|ht_link_wrapper_I|CTLCADLO_OUT_SERDES_I|oserdes_altera_inst|altlvds_tx_component|auto_generated|lvds_tx_pll|clk -name l1_rx_clk_0 l1_clk_out
# Cuts the clock output path; the tco can be unconstrained
set_false_path -from * -to }]
set_input_delay -min -1.000 -clock l1_tx_clk_0 } {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_ctrl_in}]]
set_input_delay -max 1.000 -clock l1_tx_clk_0 } {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_ctrl_in}]]
set_input_delay -min -1.000 -clock l1_tx_clk_0 } {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_ctrl_in}]] -clock_fall -add_delay
set_input_delay -max 1.000 -clock l1_tx_clk_0 } {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_cad_in} {l1_ctrl_in}]] -clock_fall -add_delay
set_output_delay -min 0.400 -clock l1_rx_clk_0 } {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_ctrl_out}]]
set_output_delay -max 1.200 -clock l1_rx_clk_0 } {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_ctrl_out}]]
set_output_delay -min 0.400 -clock l1_rx_clk_0 } {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_ctrl_out}]] -clock_fall -add_delay
set_output_delay -max 1.200 -clock l1_rx_clk_0 } {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_cad_out} {l1_ctrl_out}]] -clock_fall -add_delay
When I try the reports # report_timing -from_clock { U_HT_CORE|U_HT_EC|htxtop_inst|ht_link_wrapper_I|CTLCADLO_OUT_SERDES_I|oserdes_altera_inst|altlvds_tx_component|auto_generated|lvds_tx_pll|clk } -to_clock { l1_rx_clk_0 } -from {xd1000_ht_core:U_HT_CORE|ht_ec:U_HT_EC|ht_link:htxtop_inst|ht_link_wrapper_200:ht_link_wrapper_I|oserdes_altera9_buf:CTLCADLO_OUT_SERDES_I|oserdes_altera9_logic:oserdes_altera_inst|altlvds_tx:altlvds_tx_component|oserdes_altera9_logic_lvds_tx:auto_generated|oserdes_altera9_logic_ddio_out:ddio_out|ddio_outa_0~data_in_reg} -to {l1_cad_out} -hold -npaths 100 -detail full_path -panel_name {Report hold Timing}# report_timing -from_clock { U_HT_CORE|U_HT_EC|htxtop_inst|ht_link_wrapper_I|CTLCADLO_OUT_SERDES_I|oserdes_altera_inst|altlvds_tx_component|auto_generated|lvds_tx_pll|clk } -to_clock { l1_rx_clk_0 } -from {xd1000_ht_core:U_HT_CORE|ht_ec:U_HT_EC|ht_link:htxtop_inst|ht_link_wrapper_200:ht_link_wrapper_I|oserdes_altera9_buf:CTLCADLO_OUT_SERDES_I|oserdes_altera9_logic:oserdes_altera_inst|altlvds_tx:altlvds_tx_component|oserdes_altera9_logic_lvds_tx:auto_generated|oserdes_altera9_logic_ddio_out:ddio_out|ddio_outa_0~data_in_reg} -to {l1_cad_out} -setup -npaths 100 -detail full_path -panel_name {Report setup Timing}
The first hold relationship is -1.25 ns, which is what I expected, but the next one is -3.75 ns, which is too long. The same is true for setup, but the sign is switched. My question is either: - How can I constrain the correct edges? or - Why is this behavior correct? Thanks, Myles
