BChri3
8 years agoSome MegaWizard functions fail to generate under Ubuntu/Linux.
When trying to create a LPDDR2 (or any memory) interface, PLL, RS232, or PS/2 Controller, the MegaWizrd gets an error and then ends with a "Generation FAILED" message. This problem does not exist ...
GuaBin_N_Intel
Contributor
8 years agoI've done a quick test on mentioned three IPs, ie LPDDR2, DDR3 & PLL VHDL generation in Linux based machine in version 16.0 .0 & 18.0.0 . Although megawizard took some time to generate, it still works as expected and there is no issue found including example design generation and Verilog-based module. You may post a complete IP generation messages here and possibly find some clue where it failed at.
