Sof build failing in Fit stage with the following build message "Final fitting attempt was unsuccess
- 3 years ago
Hi @RichardTanSY_Altera and @sstrell,
Thank you for the reply. We tried to solve our problem by reducing the number of memories we use in the design. That was causing this issue. Thank you once again.
Thank you.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
