Sof build failing in Fit stage with the following build message "Final fitting attempt was unsuccess
- 3 years ago
Hi @RichardTanSY_Altera and @sstrell,
Thank you for the reply. We tried to solve our problem by reducing the number of memories we use in the design. That was causing this issue. Thank you once again.
Bookmark this main page for future reference in case you need to get more detail information on how to solve upcoming errors:
ID:188026 The Fitter failed to successfully route the design. View the Global Router Wire Utilization Map in the reports GUI and/or Routing Utilization in the Chip Planner to diagnose routing congestion. Based on the congestion information, modify your RTL or compiler settings to improve routability. Consult Intel Quartus Prime help about this message ID for more detailed advice.
CAUSE: The Fitter was unable to route the design because it requires too many device routing resources.
ACTION: There are multiple ways to diagnose or resolve a routing problem. Use one of the following methods to diagnose the routing problem:
- View the Global Routing Wire Utilization Map in GUI for overall routing congestion.
- View the Report Routing Utilization in Chip Planner for detailed routing congestion.
- Investigate signals identified by the router.
- Turn off timing optimization or alternatively just hold optimizations to see if timing constraints are the issue.
- Investigate non-global large fanout nets.
Use one of the following methods to resolve the routing problem:
- Reduce routing demand by modifying the design. Reduce the interconnect complexity by localizing routing as much as possible. For example, transform a cross-bar interconnect into a ring-style interconnect to reduce interconnect complexity and improve routability (at the cost of increasing latency).
- If a global signal is unroutable, then delete global promotion of that signal.
- Add or remove Logic Lock regions.
- Reduce very aggressive timing constraints.
- Cut timing paths on cross-clock transfers.
- Change the Fitter Initial Placement Seed in the Advanced Fitter Settings dialog.
- Enable the Fitter Aggressive Routability Optimizations logic option in the Advanced Fitter Settings dialog.
- Reduce logic utilization.
- Select a larger device.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
