ranga
3 years agoSof build failing in Fit stage with the following build message "Final fitting attempt was unsuccess
Warning (16618): Fitter routing phase terminated due to routing congestion. Congestion details can be found in Chip Planner. Critical Warning (188026): The Fitter failed to successfully route the de...
- 3 years ago
Hi @RichardTanSY_Altera and @sstrell,
Thank you for the reply. We tried to solve our problem by reducing the number of memories we use in the design. That was causing this issue. Thank you once again.
sstrell
3 years agoAs the message states, you have too much routing in your design for whatever device you are targeting.
