Small Hello World Project gives "undefined reference to 'null' Error
When I build a new NIOS Project from Template using the Small Hello World Template and then try to compile the Project, I get a "undefined reference to 'null' Error as shown on the attached Screen Shot. I have not modified the source file at all. All of the project is SBT generated straight out of the box with no modifications by me. I am using the NIOS II SBT for Eclipse tool that come with Quartus Lite 22.1.
Can any tell me what I am doing wrong
I see you have opened a thread/case regarding NIOS II on No Source Available for "" Error. It seems to be the continuation from that previous error that causes the error you have now. It is a duplicated case, therefore you may try with the workaround and solution from the previous case and see whether this error can be eliminated.
Thank you.
Kelly
- KellyJialin_Goh
Thank you.
Kelly
- WShep1
Contributor
Thanks for your attention to the request. With further investigation, I found multiple problems that were contributing to this error. I now have a working configuration and so you can close this case.
- KellyJialin_Goh
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you.
Kelly Jialin, GOH
