Small Hello World Project gives "undefined reference to 'null' Error
- 3 years ago
I see you have opened a thread/case regarding NIOS II on No Source Available for "" Error. It seems to be the continuation from that previous error that causes the error you have now. It is a duplicated case, therefore you may try with the workaround and solution from the previous case and see whether this error can be eliminated.
Thank you.
Kelly
Thank you.
Kelly
Thanks for your attention to the request. With further investigation, I found multiple problems that were contributing to this error. I now have a working configuration and so you can close this case.
