Small Hello World Project gives "undefined reference to 'null' Error
- 3 years ago
I see you have opened a thread/case regarding NIOS II on No Source Available for "" Error. It seems to be the continuation from that previous error that causes the error you have now. It is a duplicated case, therefore you may try with the workaround and solution from the previous case and see whether this error can be eliminated.
Thank you.
Kelly
Thank you.
Kelly
- WShep13 years ago
Contributor
Thanks for your attention to the request. With further investigation, I found multiple problems that were contributing to this error. I now have a working configuration and so you can close this case.
