Tried again, this time using the Wizard. Accepts the .hex file name and that part is fine.
Unfortuntely, the VHDL created by the Wizard for altsyncram uses type std_logic_vector for the address, whereas the template version uses the (far nice) natural type. Shame :( So, working, but the VHDL now has lots of things liketmpIP := tmpIP + 1; -- tmpIP is a natural IP <= std_LOGIC_VECTOR(to_unsigned(tmpIP, IP'length)); -- IP is a std_logic_vector, as per the altsyncram "address" - Altera_Forum
You can always write a wrapper component around the Megawizard generated code, just to use a natural for the address. It won't add any logic to the design, so you will have no timing or space penalty, but it can make the code nicer.
--- Quote Start --- You can always write a wrapper component around the Megawizard generated code, just to use a natural for the address. It won't add any logic to the design, so you will have no timing or space penalty, but it can make the code nicer. --- Quote End --- Darn it, why didn't I think of that :oops: Thank you for helping.
