Simulation of PLL generated by Quartus with Modelsim
When I generated the PLL with Quartus Prime Lite and simulated it with Modelsim, the PLL output c0, locked was "1'hz".
The correct clock waveform was confirmed for the PLL input inclk0. How can I get Modelsim to output correctly from c0, locked?
I uses v files for The source code , and I compile "pll.v", "pll_bb.v", "pll_alpll.v", "altera_mf.v" files in addition to the top module and testbench v files in Modelsim.
- EngWei_O_Intel
Hi there
Do you run enough cycles for your simulation? Have you seen any warning/error during Modelsim compilation?
thanks.
Eng Wei
- sugi
I run enough cycles for simulation, but the PLL output c0, locked are "1'hz".
I have not seen any warning/error during Modelsim compilation.
Do I need to compile other files?
- EngWei_O_Intel
Hi
Are all signals that you have seen a Z is at the same hierarchy as input inclk0? Are you seeing Z for all the signals at lower hierarchy or they are at Top level of testbench?
If you can share a sample example that would be good.
Eng Wei
- EngWei_O_Intel
Hi there
Since there's no response from you to the previous reply that have been provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
