sugi
5 years agoSimulation of PLL generated by Quartus with Modelsim
When I generated the PLL with Quartus Prime Lite and simulated it with Modelsim, the PLL output c0, locked was "1'hz".
The correct clock waveform was confirmed for the PLL input inclk0. ...
EngWei_O_Intel
5 years agoHi there
Do you run enough cycles for your simulation? Have you seen any warning/error during Modelsim compilation?
thanks.
Eng Wei
- sugi5 years ago
I run enough cycles for simulation, but the PLL output c0, locked are "1'hz".
I have not seen any warning/error during Modelsim compilation.
Do I need to compile other files?
- EngWei_O_Intel5 years ago
Hi
Are all signals that you have seen a Z is at the same hierarchy as input inclk0? Are you seeing Z for all the signals at lower hierarchy or they are at Top level of testbench?
If you can share a sample example that would be good.
Eng Wei
In your modelsim script can you try to add below lines:
add wave /<your_testbench_top>/<your_top_design>/<your_signal_hierarchy_level>/*view structure
view signals
run -all
