cglover
2 years agosimulation license error
When attempting to run the simulation tool it gives a fatal license error. It seems to be some sort of IP issue. I can utilize the simulation tool only at home but not at school or anywhere else. I a...
SyafieqS
2 years agoMake the path is pointing correctly.
Also, another is try to change the path of the .dat file.
Could be the path does not have permission to read causing the licensing issue.
