Simulation behavior didn't match with synthesized design
The quartus version 18.1 is used, the target FPGA is Stratix IV.
The code that is not correctly synthesized is:
assign addr = (sel1 & sel2) ? (dst == 3'b001) : (dst == 3'b000);
But the simulation behavior is the same of the synthesized design if I use instead:
wire dst_0 = ~dst[2] & ~dst[1] & ~dst[0];
wire dst_1 = ~dst[2] & ~dst[1] & dst[0];
assign addr = (sel1 & sel2) ? dst_1 : dst_0;
Are something used on the first approach that is not supported by quartus?
- Vicky1
In First approach 'assign addr = (sel1 & sel2) ? (dst == 3'b001) : (dst == 3'b000);'
dst covers only two combinations : 3'b001 & 3'b000.
In Second approach dst covers multiple combinations : 3'b000 ,3'b111,3'b001 ,3'b011 etc.
So it`s obvious that variation in Quartus report.
Best Regards
Vikas Jathar
- Pvand1
I'm not really familiarwith Verilog, but it seems to me the second part is only equal to the first part when dst = 3'b000
Does your simulion cover all the cases?
Do you have timing issues?
I might have missed deleted comments but I don't see anything about a quartus report that the above posts mentions.
- Vicky1
- 'I'm not really familiar with Verilog, but it seems to me the second part is only equal to the first part when dst = 3'b000'
Yes, you are correct, first part covers only two combination out of all combination( as in 2nd part).
Please go through the Online training,
https://www.intel.com/content/www/us/en/programmable/support/training/course/ohdl1120.html
- 'Does your simulion cover all the cases?'
It should be.
- 'I might have missed deleted comments but I don't see anything about a quartus report that the above posts mentions.'
Quartus report here I mean Quartus synthesis & simulation results.
Best Regards
Vikas Jathar
