Robert_PIN_ASAP
2 years agoSimulating inferred DSP in Questa using Intel DSP simulation library
When inferring a DSP in Verilog, what is the recommended method to simulate an actual DSP from the Quartus EDA simulation library without having to create the DSP as an IP block? I assume I need to...
HubertG
Contributor
2 years agoHi PrivateIsland,
If you are convenient, could you please provide your design to us to look into the problem for a better support to you ?
Hubert
Robert_PIN_ASAP
2 years agoThank you for the replies and interest in my question.
I was hoping to read that there is an established Quartus tool flow to produce an intermediate output of my inferred DSPs and memories that could be simulated in Questa using Intel simulation IP libraries along with my behavioral RTL / Verilog. This would be similar to the simulation environment if I had created the IP blocks using the IP Parameter Editor.
No worries. I believe I can create some custom scripts to produce my desired result.
Thank you again. You can close this one out.
