host
2 years agoSimulating 2 different devices in a single testbench
Hello, My system involves 2 FPGAs communication over a Serial Lite III interface in duplex configuration. The devices are as follows: 1. Arria 10 - project is implemented using Quartus 23.2 2. St...
- 2 years ago
Seems like some IPs are only available for Stratix 10. If that's the case you may skip steps 3 and 4, straight away go to step 5 manually compare, modify and merge the files mentor/msim_setup.tcl, common/modelsim_files.tcl and common/ncsim_files.tcl between Arria 10 project and Stratix 10 project.
Sheng
ShengN_altera
2 years agoHi,
Sheng
