12 years ago
Simple explaination I hope
I have seen some VHDL code written like this:
  SIGNAL slv         : STD_LOGIC;
  SIGNAL usg_counter : UNSIGNED(7 DOWNTO 0);
  --code to make usg_counter count up 1 count etc. every 1uS here
  proc_ConfusedDotCom : PROCESS(usg_counter)
  BEGIN
    slv <= '0';
    IF usg_counter = b"0010_0110" THEN
      slv <= '1';
    END IF;
  END PROCESS proc_ConfusedDotCom;
Can some clever bod explain exactly what is happening to the signal 'slv' here please? Is there a better way of writing this?
I know what is does, I would like to know why. :)
Cheers,
Andy
    no, this is to do with the way signals vs. variables work.
    signals are updated only when the process they are assigned in suspends. So a signal assignment actually schedules the update to occur in the next delta cycle, or in x ns if you use the after assignments:
    x <= '1' after 10 ns;
    varaibles are updated immediatly, hence why making the counter a variable instead of a signal would remove a clock delay from the process. It wouldnt exactly recreate the same hardware, as the two versions would alter the position of the output register - with separate processes the register is on the counter with the slv signal just a gated version of this register output. In the combined version, the slv is a gated version of the +1 output, with the register placed after this.
    Hence why you really need to understand the underlying hardware before writing the VHDL.
