SIMD using DSP in Stratix 10
- 1 year ago
Unlike Xilinx DSP48E1 slices, Altera DSP blocks are primarily optimized for Multiply-Accumulate (MAC) operations — SIMD-style packed adders are not as directly exposed or as flexible in the same way Xilinx’s DSP48E slices are.
Can you see if the below code help?
Verilog RTL — 4×12-bit Parallel Adder (Using ALM Carry Chains)
module parallel_4x12b_adder (
input [11:0] a0, a1, a2, a3, // 4× 12-bit inputs
input [11:0] b0, b1, b2, b3, // 4× 12-bit inputs
output [12:0] sum0, sum1, sum2, sum3 // 4× 13-bit outputs to handle carry
assign sum0 = a0 + b0;
assign sum1 = a1 + b1;
assign sum2 = a2 + b2;
assign sum3 = a3 + b3;
endmodule
Explanation: Each assign statement uses the ALM carry chain. Quartus synthesizer will map this to the dedicated carry chains in the ALMs.
Outputs are 13-bit wide to handle potential overflow.
Very efficient — no LUT wasting.
If You Want to Pack into a 48-bit DSP-friendly Add (More Complex) If you really wanted to try packing them and using a DSP block (assuming 48-bit add support, e.g., Arria 10/Stratix 10), here’s a conceptual version:
verilog
module packed_4x12b_adder (
input [47:0] a_packed, // 4× 12-bit packed inputs
input [47:0] b_packed, // 4× 12-bit packed inputs
output [47:0] sum_packed // 4× 12-bit packed results (overflow risk!)
assign sum_packed = a_packed + b_packed;
endmodule
Notes: You'd need to align each 12-bit value properly in the 48-bit word.
Risk of overflow if sum exceeds 12 bits in each lane.
Post-add masking and saturation may be needed.
This is risky since Intel DSPs don’t natively split this into SIMD lanes like Xilinx. Quartus might split this into ALM logic anyway.
Recommendation ✔ Use the first version — Quartus will map those independent 12-bit additions onto ALMs using fast carry chains, highly efficient, no LUT waste.
✔ Avoid the packed 48-bit add unless you're certain the device and toolchain will optimize it safely into a DSP block.
Let me know if the above helps to some extent. If not, we may have to leave this for a future enhancement in Quartus.
Do you have further question?
- jjxichn1 year ago
Hello Kenny,
I tried this code snippet you provided and it seems the altera is not picking up the DSP to realize it. I tried the change the bitwidth of the input and output and it does not change.
endmodule
Another question I have is how can I check whether the adder is realized by the carry chain or LUT in ALM? In Resource Usage Summary, I only see number of ALMs needed. It does not specify it is LUT or carry chain.
