Signaltap waveform display empty
- 2 years ago
Thanks for the previous response.
I narrowed down our issue. For some reason the Signal Tap enable command was not enabled in my generated TCL.
You can close this ticket.
BPR
I have not see this issue before.
It could be design itself or the signal tap configuration used is incorrect.
Use simulation to verify that the signals are behaving as expected in your design.
Try using a slower clock when assigning an Acquisition Clock.
FYI, this is part 1 of 4 training for Signal Tap training. You may go through all 4 trainings to familiarize yourself with the signal tap flow.
https://www.youtube.com/watch?v=R8vUERKTDzg
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
