14 years agoSignalTap II File is not compatible with the file programmed in the device.
I am having SignalTap II problem for a while. I get following error message when I try to program the device. Error: Can't run SignalTap II Logic Analyzer -- SignalTap II File is not compatible with the file programmed in the device. The expected compatibility checksum value is 0xB7C250B2; the value read from device is 0x7512BA8C I add a signal to signaltap and save it. Then I go to Quartun II (version 11.0 Build 208). I recompile, then going back to SignalTap II and program the device but I get above error message. I have done following so far but i still get error: - closing SignalTap II and reopen it - removing db and incrememtal db file. - deleting .sof file - even renaming the stp file to something new and changed the file name in qsf file Some have proposed to do following but I don't know how to do it: 1- .stp file is cached which needs to cleared. How can i clear the cache? 2- Disabling the on-board configuration controller. What is it and how can I do it? Please let me know any solution you may think of. Thanks Alex
