14 years agoHi Alex,
Here are a couple of different approaches to the problem. 1) Does the sld_hub and sld_signaltap instance appear in the Project Navigator? ) Try browsing to the SignalTap file using Assignments -> Settings -> SignalTap II Logic Analyzer just in case there's a path issue. 2) Try disabling the project and compiling to ensure the Signaltap instance disappears from the Project Navigator. The enable it again and make sure it comes back. Hope this helps. It looks like you are looking at the right things.
