SignalTap corruption
I'm having a problem with SignalTap II - the waveform is corrupted - signals that are known to be static toggle, states within a state machine appear to be simultaneously active, and the trigger conditions don't work properly. One clue is that with a smaller number of signals (say 10), the problem seems to go away or perhaps it's much less frequent and I don't notice it. There are no timing errors. To be sure, I added some constraints to the SDC that I found on another post. The clock for it comes out of a PLL which I've confirmed (by other means) is locked. The frequency is 50 MHz and synchronization of course doesn't matter for monitoring a static signal. My target is the DE2-115 board, which I believe has USB Blaster (not Blaster II) on it. I've re-installed the (Windows 7 64-bit) USB driver for that but it made no difference. I'm running Q 13.0 SP1. Ever have this problem? Any help appreciated!
