Signals(nodes) in Signal Tap Node Window Disappear
All of a sudden, the signals in in the Signal Window started disappearing whenever I change the view from "Data" to "Setup" or vica versa. I can get them to reappear by going down tothe "Hierarchy Display" window a clicking the box for the module that the signals are from. For example, if I have selected signals from and module called "mono_out", there is a "mono_out" entry in the "Hierarchy Display" window with a check box next to it. If this box is checked the signals from the "mono_out" module show up in the Signal Window. This box now always gets unchecked when I switch between "Data" and "Setup" and the corresponding signals disappear in the Signal Window. This did not happen until today when I switched to Quartus Prime Version 22.1std.2. How do I stop this from happening?
- RichardT_altera
The engineering team is still investigating on this.
We appreciate your understanding and patience regarding this matter.
Richard Tan
- RichardT_altera
I've successfully replicated the issue, and it appears to be specific to the Windows 10 operating system. The engineering team has acknowledged the problem and intends to address it in a future Quartus release.
The current plan is to include the fix in Quartus 24.1std (subject to change), scheduled for release by the end of 2024. Are you comfortable with this timeline?
For your reference, the HSDES ticket is [15014572807].
Thank you for your feedback, and I apologize for any inconvenience caused.
Richard Tan
- RichardT_altera
As this issue is planned to be addressed in a future Quartus release, I will transition this thread to community support.
If you have any further questions or concerns, please don't hesitate to reach out.
Richard Tan
- FvM
it seems that the bug is fixed in Quartus 24.2 Pro version. I checked with Signaltap from 24.2 stand-alone tools. It can be also used for Quartus std targets.
Frank
