Signal tap: Program the device to continue
I am using Quartus 19.1 for a Stratix S10 1SX280LN3. After successfully compiling my project with the latest .stp file created from signal tap analyzer (no warnings other than some registers pruned away) and programming the device, I keep getting the message "program the device to continue" when launching signal tap. Of course if I program the device, I keep getting the same message.
That makes it impossible to debug my project.
Many thanks for any input you may have,
BeB
- sstrell
That status message isn't always 100% accurate, especially if you program the device in the Programmer instead of directly from the JTAG Configuration section of the .stp file window. Just try starting the logic analyzer after programming the device. If it works, great. If not, you may get a message about why it won't run.
- BeB
Thanks for the feedback. The same issue arises whether I use the programmer or directly program the .sof from the signal tap analyzer window.
On top of that, I would like to enable signal tap to debug some faulty behavior at power up that happens once in a while, therefore I do not want to re-program the device once the faulty behavior happens.
Thanks again,
BeB
- sstrell
For that, you need to set up a power-up trigger that does exactly what you need: look for a trigger event to occur after device programming but before you can manually start the logic analyzer. See the debug tools user guide for details on setting up a power-on trigger.
- RichardT_altera
Regarding to the issue "Program the device to continue", you may checkout the webpage below for solution.
https://www.programmersought.com/article/27694462090/
I hope it helps.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos. - BeB
Thank you for your input, but the cable is definitely plugged since I can flash the device, and the device has not changed, it's always been the same (and the correct one) and it used to work just fine.
BeB
- RichardT_altera
Hi @BeB
I can't figure out what could go wrong for your issue.
One thing to try is to reduce the clock frequency. That may help with detecting the signal taps.
You could try to install the latest Quartus Pro 21.1 and check if the issue still persist.
Richard Tan
- RichardT_altera
I have yet to receive any response from you to the previous question/reply/answer that I have provided.
With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos. - DeanK77
This exchange was useless.
- SurakshaNadig
I had this issue and thought I could post what worked for me in case someone else faces the same problem as me.
In my case, the issue was due to a mismatch in the Configuration via Protocol (CVP) setting.
I had enabled CVP in Quartus (under device settings), but was programming the device using a .sof file without CVP support. This caused problems with Signal Tap not running as expected.
Solution:
To fix this, make sure CVP is disabled if you're not using it. Here are the steps:
On Quartus Prime, Go to Assignments > Settings > Device/Board > Device and Pin Options
Under Configuration via Protocol (CVP) – set it to Off
Also, under the same section, find Enable CONF_DONE pin and uncheck it if it's not needed.
After making these changes and recompiling, Signal Tap worked as expected using the regular .sof.
