BeB
5 years agoSignal tap: Program the device to continue
I am using Quartus 19.1 for a Stratix S10 1SX280LN3. After successfully compiling my project with the latest .stp file created from signal tap analyzer (no warnings other than some registers...
BeB
5 years agoHi,
Thank you for your input, but the cable is definitely plugged since I can flash the device, and the device has not changed, it's always been the same (and the correct one) and it used to work just fine.
BeB
- RichardT_altera5 years ago
Hi @BeB
I can't figure out what could go wrong for your issue.
One thing to try is to reduce the clock frequency. That may help with detecting the signal taps.
You could try to install the latest Quartus Pro 21.1 and check if the issue still persist.
Richard Tan
