Signal Tap invalid JTAG configuration
Start with the Quartus Programmer. Can you successfully do a standard programming of the device from the Programmer?
If that works, then you can move on to figure out why Signal Tap is not seeing the connection. Are you sure that the settings in the .stp file match the Signal Tap instance that's been programmed to the device?
- Ilaria_2 years ago
I have the same problem with my 10m25sa. No problem during programmation by usb_blaster (rev.c) with tool "programmer"(quartus prime lite) = Progression 100% (successful), but "JTAG configuration is invalid" and "instance not found" when I try to use STAP. I quote "So far I did create a new stp file, reinstalled the driver of the USB-Blaster, checked if the JTAG chain is not broken. I checked if the signal tap logic analyzer is enabled and if the signal tap is visible in the hierarchy and in the fitter report. It is all there were it should be"
Any ideas? Please help!
Thank you in advance.
I.
