RZhen11
3 years agoSignal Tap Hierarchy Display (22.1std)
Dear support, I am new with Quartus 22.1std. Using SignalTap, I found very annoying having to click select inside the Hierarchy Display every time, I changed view or make changes to the trigger sign...
SyafieqS
3 years agoBy right that should not be happening.
After selecting the node in node finder, you can see the signal added in the signal tab.
