RZhen11
3 years agoSignal Tap Hierarchy Display (22.1std)
Dear support, I am new with Quartus 22.1std. Using SignalTap, I found very annoying having to click select inside the Hierarchy Display every time, I changed view or make changes to the trigger sign...
sstrell
3 years agoCan you add a screenshot? Not sure what checkboxes you are referring to. After you add a signal to the Node List via the Node Finder, it should just be there in the list.
