TinTranDinh
2 years agoSignal Tap capture waveform
Hi, I want to capture the waveform on Signal Tap similar to the waveform on the simulation file, how can I do that?
TinTranDinh
2 years agoI have been able to get a signal from the switch but it is just a straight signal whether I turn it on or off, I want it to be able to display levels 0 and 1
sstrell
2 years agoThen you have to be able to toggle the switch at the speed of the sampling clock you’re using for Signal Tap. Signal Tap only captures data at the rising edge of the sampling clock you select.
